Help: The right screen of my PIMAX 5K appeared with a strip of violet light at the bottom and top, which is annoying in the experience.
Is it the first time its happening? Have you tried disconnecting the DisplayPort cable, or re-connect the cable on both ends? Also try to power off and on the headset and see if it goes away. This looks like a signal issue to me.
Already disconnect cables, shut down system, restart HMD, reinstall pitool, reinstall video drivers and try different configurations in pitool and steam VR and continued with the same problem. I appreciate your help SweViver
Yes, this is the first time this problem has occurred.
What is the red between lens? (Nose area)
To me, this looks like the panel or backlight has shifted position. If that’s the case, I recommend you contact Pimax Support and request a replacement.
just looks like nose space, showing fabric in the background.
