Hello, i have followed this tutorial but for whatever reason when I start SteamVR and check its version , it is always the latest version of steamvr and not the older version i am trying to install
open the Steam Console
download three packages of the old steamvr version I want to install by entering some command lines
go to:
C:\Program Files (x86)\Steam\steamapps\common\
rename the newer SteamVR folder to a different name to back it up
create a new empty SteamVR folder for the older version of steamvr I am installing
put the contents of the 3 downloaded folders into new empty SteamVR Folder
restart SteamVR and check the version
As I said, the older version of steamvr is not installed.
Never tried this but I do know that if your machine is connected to the internet steam will patch itself to the latest version if it finds its out of date
There is a way to block that inserting a code line though. I am trying going off line when I am installing the older version now. Good point and thank you!
