These are some through the lens pics of Hellblade. Default lg g6 camera settings. No zoom
P4k Settings:
Steamvr SS Default.
Hellblade set to High (very high seems to crash).
Computer Win10 Pro
Zotac mini 1080 ti (default settings)
i5-6500 no overclock
16g ddr4 2400 (2 sticks)
That not sure but keep in mind the 4k is limited to 60hz
I am getting some stuttering so should try changing pi render to 1.0.
My zotac mini is closer to reference design of the 1080 ti.
Not easy to setup the shots .
If you know of a way to activate fps in headset will try & get more details
kw23
September 17, 2018, 3:17pm
5
Does this work for the 4K?
edit: fpsVR on Steam
It might. Though may need to dig out the razer hydra if can’t setup without motion controllers
Here is a through the lense video. Bit definitely need to work on technique not as good as it could be.
Last time I test the game and compare the scale resolution between 100 and 400, when looking to the wood hill, I can know the clarity is important by this game.
I found Medium settings seems to be smoother.
