Heat Exhaust for the Sim room
Well after building the Snorkel Fan mod, which helps with the heat from the 8KX, I was having problems with my overclocked CPU and 3090 generating lots of heat in my sim room. It is fine in the winter but it is like running a heater in the room and last summer I had to run a sperate A/C for the sim room. Today I built and tested a way to remove the heat from the radiator and exhaust it down into my crawl space under the house. Just did a two hour mission and it worked very well. My case has the radiator at the top and 4 bolts made it easy to add the system that is used to remove vapors from a work area. It looks weird but it does help with the heat!
