it is good if one of the stations is initially further away. 6ft and greater.
The channels says, you have LH 2.0. I don’t know the correct channels for 2.0, but you can try 1+2 and 2+3 for the stations. There is a small button on the rearside to switch.
For LH 1.0, A+B is the Right Choice without Link cable
Me and a few others had a lot of problems with gaining tracking on the blue case Artisans. I found I had to wait sometimes up to 10 minutes for it to gain tracking. Try leaving it that long and after 10 or so minutes try rebooting the headset and then leave again. If it is the same problem (which hopefully it isn’t and it’s something silly) then you will probably want to send it back as it’s a complete pain because you have to go through that process each time you start it up or change Hz. I sent mine back and now have one of the non-blue case versions that gains tracking immediately - I guess they had a faulty batch of comms chips or something.
I’ve tried all the tips and still nothing, BUT, I tried on my laptop that has a 1080 and it works! So at least it’s not a hardware issue. Now I just need to figure out what’s wrong with my PC.
