Head Tracking in the game
Hi, while I’m playing a game, the front image that suppose to be in front of me is in the back area. How could I fix this problem so the image is facing the front of my eyes? I’m using steamvr. I hope someone can help me with this, thanks
Often there will be an option in the game to re-center the VR.
Alternatively you could re-run the steamVR room setup.
Which game are you having trouble with?
Thanks for the help, I was able to fix that issue, but I still not able to fix the lens distortion blurry at the center and edges, even after changing the IPD settings to 50MM. What settings you are using?
Hi, please reset your room setting in Steam VR
