Hey all!
Ive been trying to run Quake in VR using this mod:
The issue im having is that i cant see it in my HMD, the steamvr background dims a bit and if i open the dashboard it says “waiting” at the bottom but on the desktop the game is running, receiving tracking from the HMD/controllers as well as button presses.
Installing is real easy, install Quake wherever and then you should just be able to drop the files from the archive from github into the install directory, start steamvr and run quakespasm-sdl2.
Id be grateful if anyone could give it a try, i im pretty sure it should also work if the files from the archive are dropped into the folder of the shareware version of quake, if you dont own the full version.
