I have successfully got the hand tracker working on an old laptop, it appears to use a different set of drivers.
However, my main pc just will not recognise the tracking module. I cant change the drivers or do anything to impact how the module is recognised etc in device manager. Its definitely a driver/usb driver issue as the module definitely works.
yes I have uninstalled via device manager, tried updating drivers through there.
The leap motion shows up as a web cam, but simply will not be detected through the leap motion software and therefore cannot be used with the headset. I really dont get it as it is correctly detected and functional on windows 8.
Not sure have you file a support ticket? Sounds like the Leap Motion is being incorrectly installed by windows 10? As you mention it is being detected as a webcam?
