Hi- after purchasing the pimax vision 8KX after experiencing it at CES last week I realize there is also the hand tracking module for sale which I didn’t see a demo of at CES https://store.pimaxvr.com/shop/product/xpp2-208-0007-hand-tracking-module-315
Can anyone tell me what if any games and applications this will be effectively used in yet? Would it be able to integrate with DCS World or Aerofly FS 2 for example for being able to use your hands for manipulating switches and knobs etc in the cockpit or are there no known proven uses for it yet, as if not I can’t see a reason to get one yet… Also I already have the leap motion controller as in this https://www.amazon.com/dp/B00HVYBWQO/ref=cm_sw_r_cp_apa_i_eTGiEbT6VVKER which can be mounted on the front of any hmd and so won’t this work just as well or apart from being designed to be physically integrated into the 8KX seamlessly will the hand tracking module for the 8KX have any other advantages over the leap motion controller I already have?
Thank you
