Hi,
Pimax Crystal controllers are working just fine, but god, they are slipping.
Tried the controllers of a Quest Pro yesterday, they have an amasing “rubber skin” that is perfect.
I see there is some silicon covers for occulus controllers from third parties, do you know if there is some for the Pimax ?
Iirc I believe @SmallBaguette @Omniwhatever and possibly @drowhunter iirc did some t sting with grips made for Quest 2 controllers. Worked save you need to remove them to charge controllers
Smallbaguette’s YouTube channel is HeadsetHistorian.
Here is a link to the Beta testers earlier reviews. This link goes to Drowhunter’s post with link. He mentions mamut grips.
Pretty much any Quest 2 grips will work tbh. Bit of a tight fit but no bother, I use AMVR ones personally.
