Lebois
November 7, 2018, 7:00am
1
Hi guys !
Ok I just punshed my television while playing Creed Rise of Glory ( yeah this was a K.O. !) with vive controllers.
May I suggest to avoid sharp edges on the controller, and plan to design a kind on soft case as accessory for those who play in a small area ?
Ouch! Wii + Kinnect + Psmove. Remember watching lots of mishaps with play space.
I literally have silicone covers for controllers and HMD arriving today. Look on Amazon. I found them half the price than on eBay
Ohw damn man that sucks hope you can count on some kind of warranty or insurance perhaps …
I have also punched bits out of my plaster wall when I was in my smaller room before lol, it happens.
Having some kind of padding around the controllers would likely interfere with their tracking though I fear.
One good way is you flip your default orientation the other way around when you setup roomscale so you punch your sofa instead of your tv
Lebois
November 7, 2018, 8:14am
6
Yep that’s what i usually try to do, but sometimes i can’t do it…
On the page where you setup the room there’s a button marked “advanced”, if you click that you can click and drag to resize the play space and rotate it
If there is a TV in the area, there is no harm in putting a blanket over it to cover the screen whilst playing.
Siberdt
November 7, 2018, 12:12pm
9
