Date:
Issue Title:
Description:
HMD Model:
First 3 Numbers Serial:
Pitool Version:
HMD Firmware:
Tracking:
System Info
- Windows Version:
- CPU:
- RAM:
- Motherboard:
- GPU Model:
- GPU Driver:
- SteamVR Version:
- Oculus Version:
Date:
Issue Title:
Description:
HMD Model:
Pitool Version:
HMD Firmware:
Tracking:
Above Post made a Wiki. Choose edit Select all Copy. Reply Paste & fill in Template.
hi Heliosurge,thanks for your feedback , i will check it.
Date: 07/03/2020 Date: 7 march 2020
Issue Title:
Description:
HMD Model:
Pitool Version:
HMD Firmware:
Tracking:
Issue Title: Pimax will not connect with Steam VR
Description: SteamVR will not load with Pimax HMD loaded. If SteamVR loaded first it will fail as soon as Pitool is loaded. Pitool version has been changed and reloaded several times and Steam/SteamVR removed and reloaded several times. Up to last week there were no problems but I suspect the last change in the Pitool version has caused a problem. The HMD tracks and loads to the space scene only.
HMD Model: 5k+
First 3 Numbers Serial: 203
Pitool Version: 255
HMD Firmware: 255
Tracking: 1 x Lighthouse v1.0
@Alex.liu You can try Natural Locomotion with Index Controllers?
Have a bug, you need move the controllers hands for natural walk but in pimax the walk forward is 90º to right and need fix
This is an immersive(tons) app for gaming but is unusable on Pimax until you fix it.
HMD Model: 5k+
Pitool Version: 255/258 and others same
HMD Firmware: 255
Tracking: 2x Lighthouse v1.0, Index Controllers
