You didn’t say if the file replacement actually worked?
Hi,
Thanks for the file.
I will try it and tell you if it works.
Yes, works fine.
Some comments ago, I wrote : “But when I install PiToolSetup_1.0.1.132_212, these black bands reappear again.”.
When I replace the file “profile.json”, I install PiToolSetup_1.0.1.132_212… and the FOV is OK. No black bands in the sides.
Thank you so much, it working
Yes ! I confirm it work !
Thank you
