When I try the small fov with 500% super sampling with my gtx 1070, I still can play a lot of game such as
1 “Archangle” (black screen while loading in beginning, but after that everything look great),
2.“Serious Sam : The last hope” I can see the enemy in the long distance (you have to play until stage 4 and everything look better. With bigger fov, when enemy stay at long distance I found that it will have some white layer until all enemy move closed to you.
3 lucky tale and other,
There is wobble in some game when you turning head so fast.
I found that this make the real clarity for 5k+, every thing look clear.
In first week, I alway use the normal fov because I think the small fov is too small for the next gen of headset and I still don’t like the shape of small fov.
But when I use headset for a week and try to use small fov, I think it still be acceptable but when I boost the super sampling to 500%, wow the clarity is so great and I don’t have to annoy about distortion effect.
I think may I will use this setting for better experience until I upgrade my pc and can set performance for normal fov.
Recommend to try it by yourself.
p.s. I still can set PiTool at 1.25 quality, but I think 1 is enough.
