After getting Pimax 4k to work, I finally bought Nolo. (I wanted to play Google earth VR so much :P)
I managed to set up both (using Piplay 1.2.97) but there are a few puzzles and issues:
When SteamVR started, the green light icons on the SteamVR panel light up for the HMD and both trackers, but only ONE base station icon out of the two light up, is it normal ?
Am I supposed to see the motion trackers in front of me in VR? When in Steam Home I can see the tracker beam but not the tracker, in Google earth I can see the tracker but it is far behind me at a side. How can I correct this?
Thank you PIMAX for prompt support. An active forum is very useful indeed.
