Just got a text message from Fedex.
I hope it’s the 8KX!
It could be the eye tracker, but I’m don’t think that is coming by Fedex.
Congrats!
What backer number are you if you dont mind disclosing?
Does it not state weight or size?
I’m 29xx
If Pimax is shipping by region, hopefully some other Brits will be getting their tracking as well.
It just says the sender is Pimax.
I haven’t been asked to pay VAT yet, so hope it stays that way.
Wow im 4xx but not got a fedex notification!
Yeah, I think I will have an eye tracker before my headset.
It’s good that they are shipping the eye trackers so quickly, but annoying that the 8KX is nowhere to be seen.
You should be able to see the shipping info on the FedEx site…the label will have the weight, etc. Should be easy to tell if it’s the X or Eye Tracker from the weight. @mintus55
Just got a text from Fedex saying ‘your parcel has been delayed’.
it’s 1 kg so it’s definitely the eye tracker
I really hate being right. I wished that was your X.
I think the eye tracker wouldn’t even be 100 grams. I think it’s your 8kx
Shipping companies get the weight wrong all the time so it could still be the 8KX.
I was thinking the same thing…
The headset is well below 1kg too (1/2?). Not sure how much the packaging weighs but it sounds about right to me.
Yeah, the 8KX is approximately 800grams when I remember Sebastian talking about it. And that is 0.8kg. His package is 1kg so it’s definitely the 8KX. You should post a review when you receive it
Thanks guys, of course 1 kg would be pretty heavy for an eyetracking insert.
The package is definitely stuck in Shanghai though.
Though the parcel of two basestations weight nearly 2kgs, so
I thought Pimax had solved this problem . The drama just never seems to end .
Lol wtf, how bad are they at describing their packages?
