Fallout 4 VR Controller Problem
After a longer break playing VR, i received my Pimax Crystal and one of the first things was to fire up Fallout 4 VR.
Unfortunately the Crystal Controllers are only partly working in Fallout 4 VR? Would someone please be so kind and try, too? The Sticks are not responding, the buttons are working.
Anyone with a solution? Thanks!
The picture looks amazing! but without controllers working (do i need a certain steam VR controller profile?) it is a no-go…
Maybe onr of the Testers has tried it. @jamejame @SmallBaguette @Finn @drowhunter @Omniwhatever @CheezusCrisp
Have you tried remapping the sticks/buttons in the game?
not yet. honestly i can not remember which button is what input.
easiest would be a profile to load.
the fun thing is that the sticks do work in the steam menu when brought up. but not in game…
Yeh loading a profile would be much simpler/easier, i guess with the crystal being so new no-one has done one and made it available yet.
Hello,
You might want to try to run the Fallout 4 VR with OpenComposite and PimaxXR control center.
Or download this and extract to the FO4 folders.
https://github.com/fholger/f4ovr_improvements/releases/download/fo4vr_v1.1/openvr_api.dll
This did the trick. Thank you!
Good to hear that!
hi i got the same issue , and downloaded the dll file to fo4vr , but still missing some buttons ingame. cant get true the character in the intro scene,
pimax crystal + pimax controller
Hi, sorry for the late reply.
Haven’t had the opportunity to test it recently. I will inform you of whether I can still play without issues after testing, as well as provide details on how I’ve set it up. It used to work with PimaxXR and OpenComposite right from the start.
ok thanx :slight_smile:
i have order the lightplate so i can use my index controller,
