Fallout 4 vr and pimax 8k ,well that was awesome thanks team pimax
blue on the outside sometimes also weird cas it just go,s away
DLCVR - Fallout 4 VR and DLC standalone bug fixes
frtzngbllr’s Wasteland ENB preset for Darker Nights and True Storms
Fallout 4 - Texture Optimization Project
These are what i use ,i haven’t tried this yet but if your a fan :slightly_smiling_face:
Fallout 4 Northern Springs DLC
I just tried Fallout 4 VR for the first time with my 5K+. I’m finding that the lighting is different for each eye. Is there a fix for this? I was using the large FOV.
paralell projection on ?
I think I had it off first and then turned it on. The opening menu in Fallout doesn’t seem to render properly.
You have to restart SteamVR after enabling/disabling PP.
I was just coming back to say that :laughing: i thought restart VR app meant restarting Fallout 4 VR.
I’m running into another issue now though. When I was on Normal FOV, everything looked great. When I increased it to Large FOV, the resolution of everything dropped down. What settings should I be using for SteamVR App Resolution vs. Pi Tool Rendering Quality?
I’m on an RTX 2080 Ti. With my Vive, my processor was the bottle neck for FO4 VR so I’m pretty sure I have a bit of GPU power left.
to be honest i use small fov its more than enough and performs flawlessly for me
steam SS 30% fallout application SS 100-150 % whatevers good for you really but this is with pi tool @ 1.5
looking into it further, it appears to be an issue specifically with the large FOV. i guess they’re still working out issues with it. i just went back to the Normal FOV and i’ll just have to use that for now.
handy tip ,if shooting a scatted laser pistol or similar hold it gangster style it will shot straight :hugs:
