Hi,
I may just be the only Indonesian here who backed and have received the product. But I’m not sure what to do to get the promised $100 store coupon. Are there links that I need to go to in order to receive it?
Regarding the product, when I put it on, my eyelashes touch the lenses and it’s pretty difficult to get it fit snuggly on my head to enjoy the experience. Is there anything you can suggest?
The face pad that the headset is supplied with is not the best. Try a different…maybe thicker face pad. Failing that you could get strips of double sided velcro…remove the face pad and lay the strips on the hmd to the desired thickness then place the facepad back ontop of the strips you’ve layed. Hope this helps.
I changed the strap with Vive’s DAS and switched the foam with the one I got from VRCovers which is also for Vive and it fits surprisingly well.
Will definitely try and find me double sided velcro tape. Thanks for the advice!
