Eye tracking DFR in iRacing
I guess this is a question for @SweViver as he’s the only person with an eyetracking unit on an 8KX. Does DFR work with iRacing, currently FFR doesn’t work with iRacing so I’m guessing DFR won’t either. When you get a moment could you confirm please, i only use VR for iracing so that’s my main concern?
Thanks in advance :slight_smile:
+1 also need an answer
Iracing yes please​:+1::+1::+1::+1:
If ffr doesnt work then no it wont as its exactly the same process just with eye tracking defining where the high and low res portions are instead of assuming center.
I can confirm that DFR does not work with iRacing… Bad news
Thanks for confirming. TBH I’d never buy from here again anyway so had ruled it out, there’s no way I’d invest anymore into Pimax products, it’s not worth the pain.
