this what it looks like when i take a screen shot
i see the pictuer horizontal…screen side on
Hi,
I had similar issues with the Piplay display going crazy.
Try changing the resolution of your PC monitor. Try different resolutions.
This seemed to help fix my issue.
Definitely a Piplay software bug.
Hi, please do it like this:
Right click on desktop, choose “display settings” , you can see two screens.
And then you can change the Orientation. Thank you so much!
