I’m sure you’ll look at PIMAX 5K + review, most of them are still passionate about VR.
So it’s possible that you may already have VR device on your side.
Whether it’s a VIVE OCULUS MR or a phone, simple VR.
There must be a question.
That is, is it worth to spent money buy PIMAX 5K+ or make an upgrade for you old VR device ?
I’ll come to a conclusion in advance. it’s worth it.
why I’m saying this.
let me tell you why i recommended it.
The first point is that it’s about the same or even better as VIVEPRO, so you can barely see the grid, so it’s perfect for looking at the virtual world.
The second point is the 200-degree view angle, and basically what you see is the surface of the game, and there’s no black zone.
Compared to VIVE,VIVEPRO, you’ll see the black zone above and down on the left and right when you use it.
For example,I would like to ask you to put this hand like picture in front of your eyes
That’s probably how VIVE and the other VR helmets feel.
And the feeling of 5K + please put you hand like picture in front of your eyes .
Can only say that there is a big increase in the sense of feeling.
You don’t have to look at the virtual world with cursed equipment periscope anymore.
That’s the only way to call it a real VR.
In addition, with VIRTUAL DESKTOP software, even if it’s used to watch comics, watch movies, or play ordinary games.
Because there is no influence of the grid can be very perfect to show the real display like monitor.
All I can say is that I don’t even want to use my SAMSUNG43-inch 4KHDR screen in front of me right now, but I want to use PIMAX 5K+ to looking at these visual content.
I really enjoyed it with a big screen.
Part relating to the game
many people worry about most is the problem of compatibility
Basically, many of the hot games I’ve played are compatible.
The common cause of errors is relationship with too high resolution in per eye.
Basically, you can solve it by going to PITOOL to lower your Reder Quality setting.
However, the display of the game just like the strongest VIVE PRO level with no periscope.
Apart from being amazing, I can’t think of a better adjective.
I’m sure no amount of text can help people understand exactly what it is.
Here, let’s show you the MI9 ultra-wide angle camera to Make a video, which was sold not long ago.
The quality of the film is ultra-wide Angle 4k30fps
The PITOOL renderquality is 1 field of view set to normal per eye resolution is 2601*2140 without steamvr supersampling
There are straight black in video but when actually using 5k+ it will not appear.
The first actual gameplay in The Blu.
And then here is the VirtualDesktop display of watching videos and comics.
Comics
Youtube4kVideo
Play a 180-degree 3D 4k video by using slr
The last actual gameplay in playhome
Because the focus problem video is not very clearer,actual display will like the following picture, and it will clearer than the picture.
Are you satisfied with the display quality of 5k + and the large angle of view that covers all the viewable ranges?
This year, VR’s new product, whether it’s VIVE COSMOS or Oculus Rift S or even Valve Index,
Neither device has a significant increase in the viewing angle, so PIMAX with the largest viewing angle at this moment can be said to be the best choice.
So hesitated to spend money, and then it’s going to have to wait a while to get it.
All I can say is that the money and the wait will be worth it.
What should I do first after receiving 5k +?
I got it on April 3rd.
Compared with my previous VIVE, the transfer box is a lot simpler.
There are no more lines.
The weight has also been significantly reduced a lot.
In addition, the head weared must be installed by you own.
This side will first introduce how to deal with it after it is installed, which is better than how to deal with it.
When you put it on, you have to put it all together so that the weight depends on wearing it on your head, not on your face.
Basically, the most important thing is that the median line will slide if it’s not fixed.
The weight will all pressed up on the face by the mask.
It’s a terrible experience.
But the solution is very simple.
Go to the store, buy the Velcro, cut off a small piece of face and adjust it to a suitable position to stick to it.
So there’s no more sliding up and down.
And then adjust your head so that the lower half of the mask doesn’t feel like pressing your face.
Then you have to install PITOOL.
The latest one is here.
http://piplay-us.pimaxvr.com/PiToolSetup_121_R211_beta.exe
Added adjustable brightness or eye distance at any time.
Basically, after installing the program, if you can not see any display in 5k+.
Please restart your computer.
And then open PITOOL.
And there are a few special things in the picture that need to be set up.
First of all, make sure that 5K + is tracking by LIGHTHOUSE and then start making room setup.
Just set the front position for your play and the floor.
And then it’s basically ready to use.
But don’t worry.
Change the settings based on the hardware first
The uppermost part of a brightness adjustment.
I recommend set it to low.
Because LED uses the backplane to emit light.
Coupled with a Fresnel lens will cause reflection, commonly known as the god ray, which affects the appearance of the display.
And the contrast and brightness adjustment can be changed at any time.
Adjustment in the game can immediately reflect the change
The most important thing is to adjust the render quality, that is, the resolution.
Adjust according to your video card.
PS: adjustment render quality you must closing STEAMVR first, and modify the PITOOL render quality value then restarted STEAMVR.
As shown above, in a normal visual angle, 1 100% of the situation is in a situation of 1 100% of the quality.
The resolution of per eye is 32022634.
And my display card, 1080TI, is basically can not handle it.
So STEAMVR recommend me change resolution down to 66%, per eye resolution 26012140.
Basically, the monocular resolution of 5K + 2560*1440 can be display completely.
PS: different field of view will affect the resolution and performance because of increase content in the game will be calculated at the same time.
Basically, it will affect the performance of the FPS, so you may need to reduce the resolution of the per eye further.
So i recommend uses normal or small field of view.
PS:The difference of field of view setting.
For example watching movie in the cinema.
In normal or small setting.
The IMAX film can only see the screen on the left and right, not the border frame.
After adjustment field of view to be big.
The leftmost and rightmost border can be seen.
But what you can see is the same as the 200-degree viewable display with small or normal field of view.
PS: saw that there were two display in the display. there was no 3D effect that could not be correctly displayed.
Please shut down the game and OCULUS STEAMVR first.
Open BRAINWARP compatble with parallel projection
Open STEAMVR again and checking per eye resolution
And then lower your supersampling value.
PS:OCULUS games are usually calculated directly on the basis of the render quality set by PITOOL, so some tours will jump out of the error because of the high per eye resolution. please use PITOOL to change the render quality to 0. 75 or 0. 5 and then start the OCULUS game again.
PS:STEAM games you must start STEAMVR from the PITOOL first.
An error occurred in the STEAMVR because of started the game directly.
Introduce these basic uses and possible errors.
In fact, most of the reason is that the per eye resolution is too high, so you can know how strong the basic resolution of 5K + is.
If there’s an unsolvable problem. it’s easy reboot pc and then open pitool again, most of problem can be solved.
I hope everyone can enjoy the strong visual impact by the large angle of view and the high quality VR.
if you like my review please go here to vote my number 39 thanks
https://community.openmr.ai/t/pimax-official-activity-voting-period-sharing-your-gaming-experience-with-pimax/16183
享受真正的無界VR 小派5K+體驗與相關教學
想必會看小派5K+的評論現在大部分都是仍然對VR充滿著熱情的玩家
所以可能身邊可能也已經有VR的設備
不管是VIVE OCULUS MR或是VR一體機或是手機的簡易VR
想必都會有一個疑問
那就是究竟小派5K+值不值得花錢去買或者是將舊有VR設備做一個升級呢
總之我就提前先做個結論那就是非常的值得
至於我為什麼會這麼說
那麼就來說一下到底PIMAX5K+為什麼那麼值得推薦呢
第一個要點就是跟VIVEPRO差不多甚至更好的螢幕呈現讓你幾乎看不到網格也因此能完美呈現出實際的畫面
第2個要點就是200度的視角基本上下左右你看到的都是遊戲的畫面而不會有黑框的存在
相比VIVE,VIVEPRO在使用時左方 右方 上方 下方 你都會看到黑框的存在
舉例來說請你比出這個手勢放在你的眼前
這大概就是VIVE跟其他VR頭盔的感覺
而5K+的感覺請比出這樣的手勢放在眼前
只能說帶入感大幅的提升再也不用裝備遭到詛咒的潛望鏡來觀看虛擬世界
只能說這才能叫做真正的VR阿
除此之外搭配VIRTUAL DESKTOP軟體就算拿來看漫畫看影片或是玩普通的遊戲
由於沒有網格的影響 可以非常完美的呈現出實際的畫面
只能說我現在都不怎麼想用我眼前這台SAMSUNG43吋4KHDR螢幕而改用5K+直接去看這些視覺內容
畢竟用大螢幕爽度非常高阿
至於遊戲的部分
很多人最擔心的就是遊戲兼容的問題
基本上我玩過的多款熱門遊戲都有兼容
出現的錯誤通常原因就是單眼解析度太高的關係
基本上去PITOOL把畫質調低都能解決
而遊戲呈現出的效果有目前最強VIVE PRO等級的畫面外加拿掉潛望鏡
除了超讚之外我也想不到更好的形容詞
這邊就用不久前發售的MI9超廣角模式呈現給大家看吧
由於只看圖片的話可能比較不準或是有修圖
所以我用影片的形式讓大家看看實際效果大概是如何
影片錄製畫質為超廣角4k30fps
PITOOL設置畫質1 視角為普通 單眼解析度2601*2140 未經過超級採樣強化畫質
還有影片的直黑條實際使用5k+是不會有的
首先就是 The Blu的實際遊玩
优酷http://player.youku.com/player.php/sid/XNDEyOTY0NDYyOA==/v.swf
然後接著是使用VirtualDesktop觀看影片跟漫畫的效果
漫畫
优酷http://player.youku.com/player.php/sid/XNDEyOTY0MzY5Ng==/v.swf
youtube4k影片
优酷http://player.youku.com/player.php/sid/XNDEyOTY0MzcyNA==/v.swf
使用slr播放180度3d的4k影片
优酷(屏蔽)
最後這是playhome的影片
优酷(屏蔽)
由於對焦的問題實際的畫面會更清晰像是下面圖片實際又比圖片還清晰
不知道看完的人對於5k+的畫質跟包覆住全部可視範圍的大視角還滿不滿意呢?
今年VR新產品不管是VIVE COSMOS 或是Oculus Rift S甚至是Valve Index
不論哪一款都沒有針對可視角度去進行大幅度的增加 所以目前最大視角的小派產品可說是最佳的選擇
只能說可惜的就是VR最需要的就是使用實際產品讓人體驗
如果同時擺放一台VIVEPRO跟一台5K+的話同時讓人去體驗
在做個體驗滿意度調查的話
我相信大概所有人都會選擇5K+吧
所以還在猶豫該不該花錢然後還必須等待一段時間才能收到
我只能說這筆錢跟等待都會是值得的
那接下來就介紹一下5k+收到後首先該做什好呢?
我是在4月3號收到的
跟我之前的VIVE相比轉接盒簡化了很多
線不再有那麼多
重量也明顯減輕許多
另外頭戴後面要自己裝上
這邊就先介紹裝上後如何處理比較好
畢竟裝上後要盡量讓重量依靠頭戴去支撐而不是靠面罩
基本上最重要的就是正中間的線如果沒固定住就會滑動
導致重量全都靠面罩往臉上壓
這樣體驗起來很糟糕
不過解決的方法非常非常的簡單
去商店買魔鬼氈 剪下一小塊 面部調整到適合的位置黏上去
如此一來就不會再上下滑動了
然後就將頭戴調整到面罩下半部不會有壓臉的感覺就對了
那麼接著要安裝PITOOL
目前最新的在這
新增了可隨時調整調整亮度跟對比眼距
基本上安裝完程式插上5K+發現沒畫面
請重新開機電腦
接著開啟PITOOL
而圖片裡有幾項特別需要去做設置
首先確定5K+被LIGHTHOUSE都抓到沒問題後開始做房間配置
就照著畫面設定你遊玩的正面位置還有地板這些
然後基本上就可以用了
不過先別急先要根據硬體去更改設置
最上方的亮度調節的部分我是推薦調成低 由於LED利用背板發光的特性配上菲涅耳透鏡個人覺得會造成視覺上菲涅耳透鏡的反光也就是俗稱的聖光影響到畫面表現
而對比度跟亮度調節的部分是隨時都可以更改的
在遊戲中調整立刻就能反映出改變
另外最重要的就是畫質調節也就是解析度
根據你的顯卡去進行調整
PS:調整畫質必須先關閉STEAMVR,修改PITOOL畫質數值之後在重啟STEAMVR
如上圖 在普通視角 畫質1 100%的情況
單眼的解析度是3202*2634
而我的顯示卡1080TI基本上是無法負擔的
所以STEAMVR推薦我解析度降到66% 單眼解析度2601*2140
基本上5K+的單眼解析度2560*1440基本上已經能完整呈現出畫面了
PS:不同視場角會影響解析度也因此會影響到效能 因為同時要計算的遊戲內物體增加
基本上會影響到效能FPS降低導致你可能需要再往下降低單眼解析度
所以基本上1080TI的話推薦使用普通或略小視場角
PS:市場角差別就在於遊戲內同一個畫面 以電影院舉例的話 IMAX電影畫面最左右只能看到螢幕不能看到邊框 視場角調大之後 最左最右的邊框都看的見了 不過開普通跟略小視場角你能看到的也同樣是200度的可視畫面
PS:在頭戴裡看到遊戲畫面是2個畫面沒有3D效果無法正確呈現時
請先關閉遊戲跟OCULUS STEAMVR
開啟BRAINWARP的兼容使用平行投影
接著調低你的PITOOL畫質數值
再打開STEAMVR並確認現在的單眼解析度
下圖是畫質1 普通視場角 兼容使用平行投影後打開超採畫面呈現的數值原本設置是上圖修改成66%單眼2601*2140 因此沒修改超採到44%左右會有很大的可能跳出錯誤
PS:OCULUS的遊戲通常都會直接以PITOOL設定的畫質去計算,也因此有些遊戲會因為單眼解析度太高而跳出錯誤,這時請去PITOOL把畫質改為0.75或是0.5再開OCULUS遊戲
PS:STEAM遊戲務必從PITOOL畫面啟動STEAMVR才去開啟遊戲
直接開遊戲自動啟動的STEAMVR會發生錯誤
介紹完這些基本的使用跟可能發生的錯誤
其實大部分原因都是解析度太高造成的因此能知道5K+的基本解析度是多麼的強悍
真的有無法解決的問題很簡單重開機後再開啟pitool大部分都能解決
希望大家能夠享受到大視角與高畫質VR所帶來的強烈視覺衝擊
如果喜歡我的文章麻煩到這幫我39號投個票 謝謝
