Hi I just got a pimax 4k and am finding some really heavy blurring around the edge of the lenses, kodi in media mode is almost unusable because I can’t see the edge. The centre isn’t too bad and I think some ipd tweaking will sharpen up the middle bit. Question is, is the edge blurry for everyone or is mine faulty??
Thanks.
I have the same issue. Looking to the side is uncomfortable and I don’t have this problem with my cheap Fiit VR smartphone headset lenses…
Edges of the lenses are blured by all headsets, at least i can clearly remember that i had to look exactly to the center by the vive and oculus in order to read something.
It’s more prevalent in the Pimax though
