Thanks, good input.
What is the settings to make PE higher fps?
When i am in PE only, my gpu and cpu are very low utilization.
oh, will that be: common settings, gpu ?assessment - can not think if the name.
Thanks, good input.
I donāt use PE, so unfortunately, I cannot help you troubleshoot that.
Just updated motherboard Bios and update AMD Radeon Adrenalin 21.4.1
Looks like it is working now.
I still have very slight double vision in PE (but nothing like before, and I could probably not show it here. I only know it is there, because I am looking for it.
It is fine.
I am not sure this is the same issue, but probably is or related; If my FPS is lower than Hz there is jittering. e.g. Project Cars2, or DCS.
I may be able to put up with it at the beginning of a race, 18 Cars ~ 80 FPS with Jitter, then after the first corner 90 FPS no jitter.
I have the exactly same problem in DCS, smart smoothing makes everything blurry, like there are 2 images superimposed on eachother. And also for me without smart smoothing I can get 80-70fps but with smart smoothing turned on it drops to 35ish fps this is with a 6900XT.
yes, that sounds the same issues i have.
let make a ticket, and discribe it better?
i think the ss frame is not in the same position as the original frame.
Iāve had a ticket open for about a month. Been going back and forth trying things. So far no luck.
can i access that?
can i read it?
basically, where i am now is:
must hit hz with fps.
if even slightly lower fps than hz, bad.
Yea, same exact problem here, and if I try to use Smart smoothing toā¦ smooth it out, the performance drops 80% and double image blurriness + huge stutters. But turn smart smoothing off, and bam, instant 80% increase in FPS, double image gone, and only sutters when fps dips below refresh rate.
I suggest you make a support ticket as well, maybe they can help you. So far they had me update my mobo bios, edit a json, and try a different USB plug. Smart Smoothing problem still persists.
i have read, here, that Nvidia users can brop below the hz with smoth fps.
i have told pimax about it, abd they blanked me.
i should make a new ticket, and try again.
today, i maxed out all settings, on project cars 2, but reduced reselution to 60% in steamVR. hit 90 in rain at night. i really enjoyed it.
it seams to be a ss or drop frame issue.
if i turn on ss, i get two imagines, ofset, next to each other, very frustrating. beacuse, it is obvious, it could be fantastic;IF.
I canāt help you fix your AMD issue; but I CAN help you fix the PCars2 issue, by telling you how to get rid of it:
It really is orders of magnitude better. Wide FOV, 100% or more Steam SS, eye-candy all the way up, and youāll still get better performance than PCars2 will give you at Small FOV.
Itās a bit of a learning process to get it all done, but itās so worth it. (Note, Iāve also found I can tolerate 60hz no problem in Racing Sims since they are seated. I run AC at 75hz most of the time for more fluid motion anyway, but if you can tolerate 60fps you may be able to crank up the SteamSS or PiTool quality.)
I have Nvidia 2080ti, and smart smoothing is working mostly. Especially if I just turn on my game and just start to play it.
But if I have long ladings (some games, like IL-2, with big maps and many players), or if I let my HMD on table a few minutes (steamvr pause is disabled/enabled, it is same), then smart smoothing does not work good, it has strange effect, like looking trough fluid, with many artefacts. Also my tracking then behave bad, like lagging a lot.
My conclusion, it is much better with nvidia (when works, then it is excellent), but for some cases I just can not use it.
I agree about AC vs PC2, i have both and AC with SOL and CSP and a load of other mods (mainly cars and tracks). I love racing around in cars that iāve owned irl. The mods make AC shine.
Thanks for the info. Since then, I have got Assetto Corsa. Played only a bit. I was having trouble getting the response time down. I do not have any mods (yet).
But really this is about Smart smoothing.
Just thinking about this:
It may all be different with the latest pitool and firmware? Meaning maybe the problem is fixed. The issue with updating is, I will not update until it is working better. Not much point updating from something I can use (but with problems) to something that has a lot of new problems.
I am still using 1.0.1.271. 1.0.1.274 has its own problems.
Oh, I should update!
I just updated to 1.0.1.274
Different problem.
Still smart smoothing is not working. but it is not like i described before.
