Uncheck and check ‘compatible with PP’ but no change.
Any ideas please?
Any ideas please?
Have you restarted SteamVR and the sim between the changes? (Enabling/disabling PP needs SteamVR restart). It should work fine with PP on, last time I checked.
Roger that my friend. Thank you. Thought it was just pitool restart. Duh
No problem Enjoy mate!
