I’m worried about scratching the Pimax lenses if I wear my glasses with the headset.
Yea, seems like it does.
Initial reports indicate there is room for glasses. If this is a major concern for you, consider waiting until initial reviews are posted.
My glases fit with vision (comfortkit).
20char…
you could also use peal n stick pads trimmed as spacers so if contact happens it’s the spacer that touches.
It depends on the glasses. I have a large (wide) ones and I had to increase the facepad thickness to 20 mm to avoid scratching the lenses. The critical points are the outer rim tips where the support joins the frame.
I can imagine with a narrow face you won’t have a problem.
