I heard that the 4k has pretty bad ghosting and it uses lcd. But the 5k and 8k uses clpl lcd, which eliminates ghosting. Is this right?
Yes, that’s correct.
That’s good to know!
According to LinusTech, it does not eliminate ghosting.
According to LinusTech prototype 2 has IPD adjustment too…
Right, just watched it. Now, it is getting me a little worried…
Yes,you are right but not clpl lcd just clpl.
By the way, linus tech tips’ was using a V2 prototype, I heard that V3 was much improved compared to V2.
