I had it off and had some super distracting pop in on the edges of the screen on all FOV settings. I switched on pallarell projection and the pop ins disappeared but the performance took a hit and it’s noticeable.
The physics on this game are crazy I just wanna enjoy it yknow I tried simple things like throwing that round thing in the air and hitting it with the bat and it becomes difficult with the performance with pallarell projection on.
Anyone know how to rid of the pop ins so I could enjoy this game with pp off?
I tried large, medium, small, potato FOV with pp off its like I can see everything on the sides load stuff from the game. It’s like even on the launch screen on the green grass I see black glitches right on the corner. Then it goes into the height setting screen which works perfectly and then the home screen has glitches again.
If you see the culling in the native mode and not in the PP mode then it is clear the game engine is buggy and calculates incorrectly the total horizontal FOV in the native mode (probably by adding the individual eye FOVs and forgetting the view canting). This should not be difficult to fix though (I hope).
The only issue I’ve seen is object culling meaning objects disappearing too early (i.e.almost at the periphery of the view - to the sides) as the game engine seems to think the FoV is smaller than it really is… It’s not game-breaking if You don’t look to the sides.
Haven’t tried 72Hz though and I always play with Smart Smoothing on (120Hz, Normal, Smart Smoothing on, no offset).
No culling either.
I never use Smooth, I find it has about the same artifact intensity as ASW1 did. Have tried it in BW and found it made graphics slightly less sharp, as well. Slightly
Here’s something interesting.
I hadn’t tried Large fov and thought I would check for culling. There was some although minor.
I then returned to Normal and the culling persisted.
I rebooted the pc and launched Pitool which in my case defaults to Small fov at launch. Annoying but it shed some light in this case.
Going from Small to Normal, I then had NO culling in the game.
Probably why I hadn’t seen any before, starting in Small every time I launch PT.
