I didn’t install DMAS until yesterday. What an ordeal!!
The screws were so tight that it was imposible to remove them with the pimax screwdriver. I had to buy another one better. Then I could remove one but the other was imposible because it lost the mark trying to loose it.
Then, I had to use my DREMEL to be able to cut a mark and then use a screwdriver again. Pimax should be careful to use the right power when tightening screws. I could have broken my DMAS.
Agreed the screws seem to be torqued on pretty tight. I would prefer something more like a torx.
Torx would be better. Maybe a small plastic pack with extra screws too? They’re so tiny that if you drop one it would be darn hard to find!
