Distortion caused by display or lens?
614/5000
Hello @Sweviver,
I use google translation.
could you take out the lens of the mask with the sucker and put it in front of your PC screen and see if you see the distortion or not.
I would like to know if the distortion comes from the lens or the pimax display.
on the image without the lens with the boat in the water, we can notice that the display has a distortion on the end. So it may be only a display problem and not a lens problem.
Could you take out the lens of the mask with the suction cup and put it in front of your PC screen and see if you see the distortion? thank you.
Distortion caused by distortion profile which make image to distort and be related to the lenses, but the distortion still can be available by othet factor such as ipd, eye distance which make people has different angle of view.
