I have a display port extension (15m / 50FT) and a adapter (female/female). It works perfectly with valve index, but not with a pimax 8k X. I think the problem is the adapter. I tried two adapters (one passive and one active), see below for details.
Could anyone suggest an adapter for me (preferably: passive), pls?
Hey DrWilken Want to ask you smth.
Quote from previous thread:
Passive DisplayPort Cables (male/male)
I only tested a few passive cables with the Lindy 38415 Repeater and 5 meter passive cables didn’t work but if 3m is enough for You I would think any good quality DisplayPort cable at 3m length would work as long as it’s coupled with the repeater.
Cable Matters 8K DP Kabel (Displayport Kabel 1.4) mit 8K 60Hz Videoauflösung und Unterstützung von HDR - 3m - Kostenloser Versand ab 29€. Jetzt bei Amazon.de bestellen!
16,99 €
Do you mean “3m” or “3m DP (geflochtene)”?
And if I want 1,8m - will it work too with Lindy? Then what cable I should choose “1,8m DP” or “1,8m DP (geflochtene)”?
Lindy repeater became USD 90.55 instead of 101,98 € on those link. Seriously cheaper. Is it still the same, didn’t they replace it with something other?
