Hi,
I know it’s old stuff, but I am wondering if anyone knows what are the differences between 8KX versions 2075 vs 2076? Are there any differences in color reproduction?
Thanks!
Hi,
Thanks!
8kX 2075 & older
8kX 2076
I did at one time start a topic on Pimax models in a chart.
Found it
Consider joining & provide feedback on my site
Link good for 10 uses
Features advanced help topic using a template form and a special category where the Op can choose a reply as best solution.
Also added RSS feeds from RdToVR, UploadVR and Skarredghost. Also have a YouTube feed from Pimax channel and pimax updates from OpenMR. And much more (chats like Discord as well) & still lots to do yet.
Features a cleaner interface. The help category with the form template is in Planet Pimax Category.
Thank you. Any idea on “newer screens” vs 2075 screens, what’s the difference?
I don’t know anything concrete.
But it would seem the displays have maybe better stability and likely color improvements.
I have not experienced the newer model.
Maybe @PimaxQuorra & @PimaxUSA might be able to supply some details.
I have both a 2075 and 2076 head sets and the 2076 appears to have panels with lower image persistance. I recently tested the 2076 to make sure it works before selling it and that was really the only difference I noticed between the two headsets. BTW if your interested the 2076 is quite literally brand new as I had to borrow a 3000 series gpu from a friend to test it before offering it for sale on several forums and it’s still available.
Thanks. What about the colors between 2075 and 2076?
Color saturation does appear to be slightly better on the 2076 but it may be more a result of the lower persistence mentioned earlier. I’m no expert in this matter these are merely my thoughts upon my short term observations.
