Just started using RC… I notice the max resolution it’s allowing to select is 2560x1440 This seems to be a limitation of steamvr? Or riftcat?
Any way my s8+ supports 2960 x 1440
Is there any way to edit something to force this resolution?
Thanks so much
Riftcat\Config
Edit vridgeQuality.cfg with a text editor.
“Width”: xxxx, “Height”: xxxx,
Superstar!!
Will test later
Just out of curiosity, do you use Gear VR as Headset with the S8+? If so, can you publish a stable and fluent working config file? I have huge Problems with some kind of lagging experience with riftcat while using the Gear VR.
I’m using wearality sky
It wouldn’t work at 2960x1440 for me
To be honest it just doesn’t work good even when it does
