Hey guys,
I just had a look at the current owner upgrade plan in the pimax store and am a bit confused about the prices. It doesn’t matter which headset I select under “Owned Headset” the price doesn’t change. This makes me wonder why we can even select the current owned headset if it does nothing. Am I missing something here? I consider to upgrade from my 5k XR so I’m just curious
Best regards
I’m not sure but discount might not be applied until you put your original Order info in.
@Matthew.Xu can you confirm?
Hi @Salvoid7,
Sorry for my late reply. According to your description, I have attached some screenshots for your reference. Thank you
