Crystal microphone problem
Often with starting my crystal and other programs, my crystal mic is not recognised.
I found what was the issue; I need to start pimax client and wait (longer) untill it start mic and headphones driver; only then I may open discord (or other program with mic issues). Otherwise the mic are not recognised.
I have 2 ways to make it work again:
  1. PC restart, then pimax experience (+wait untill crystal recognised and fully functional)…
  2. If you still have problems, switch in pimax experience to “normal sound mode” (restart headset), and then switch back to sound “low latency - experimental mode” (which is far better).
  3. still problems? Make step 2) and then 1)
To pimax engineers; can you make pimax crystal mic (and headphones) always working with PC? That was case with 8kx, and that was more convenient for gamers.
Roger that!
