Since updating to: V1.3.0_au905
And Controllers: 0.8.22.
After going through the room set up process it works once. Then, after one session, hands are no longer tracked.
Is there a fix for this? Works once then stops.
Any help appreciated.
Thanks,
John
Hello John,
The controllers are no longer being tracked and are flashing on the client. Please try pressing and holding the π logo for 9 seconds until you see a flashing red light followed by a vibration. This will reset the controllers and may help resolve the tracking issue.
