Controls unresponsive
I have noticed using pimax with steamvr for several unity titles, the keyboard controls don’t work.
They do work when opened with oculusvr but the oculus vr lacks the configuration screen and so resolution is alot worse for some reason.
Anyone else have similar issues?
At times, I experience the same behavior. I need to close and re-open steamVR to rectify it. I figured it was an issue that was related to all HMDs, but I only have the Pimax.
In addition, at times, I don’t get an HMD cursor where there should be in an application. It just doesn’t show, so I am unable to use the software. (I know there should be one from videos and or screenies) For now, I have stopped purchasing VR titles until I can get a handle on it.
I also think that the steam controller should be able to emulate a tracked motion controller (because of the gyro capability), but I haven’t got that resolved yet either. Again, for now I stopped purchasing VR software with motion controller support only. I like supporting software developers by purchasing software, so I hope I can figure it out or, more come back to supporting motion controllers only.
