Yesterday controllers were working fine. However today, i tried using different usb extensions to see if they work (they didn’t), so when i switched to the normal usb port i was using without extensions the pimax display and audio worked again. But now, controllers aren’t appearing lol… Tried different usb ports, no difference. Then i tried pairing from pitool, and it gave me this weird message in the pic below. What to do?
Restart the pilauncher service
did that, also uninstalled pitool and downloaded the latest one, nothing. Still giving me that weird (Not enough dongles detected" error whenever i click the “pair controller” button in pitool
Hmm, guessing by your picture, i believe that the USB drivers might not be installed.
Can you take a picture of your device manager ?
restart fixed it for me
Aaargh, just one controller shows up. The other one turns green as if it connects but it doesn’t show. Restarting pilauncherservice is not helping
i uninstalled pitool, changed usb ports, restarted pc, installed pitool again, turned on the headset using the power button, then worked again
I hooked up my 5K+ again and it needed pairing with the controllers, pairing both controllers with the 5K+ is working.
I will now switch back to my 8K again and see if that goes well too.
Result: Nope. Now it doesn’t want to pair with anything, I get the ‘No enough dongles’ message immediately.
Had to restart pc too to get me some dongels freed
Weirdest sh*t, not enough dongles lol.
Poor dongles, all filled up but nobody to talk to.
