I haven’t received the deluxe package for my Pimax 8KX so i bought the vive controlers and 2 2.0 lighthouses.
In the Pitool only 1 light house is showing active. I’ve plugged it in and unplugged it about 5 times, controllers pair but can’t see hands in Steam Home and can click to see move spots but have no teleport options to move. Controllers aren’t working.
This reminds me of the nightmare i had with the Oculus Rift initial set up and times when it screwed up.
What am i doing wrong? Do i have the wrong controllers. I still haven’t gotten the ones with the deluxe package so i got these from Amazon from HTC.
You use a little pin/ballpoint pen to press the button in the little hole on the back of the basestations to change channels as far as I understand (I don’t have v2 lighthouses).
Next to were you put in the power in the lighthouse it is a button you can push, if you have steam vr running you can hower over the lighthouse to see what channel it is at.
just to be complete: yes, you can (and should) change the channel number on a second, third, … lighthouse V2. Operating 2 on the same channel does not work - only one will be detected.
I’ve tested to set mine to channel 0x01 and 0x02, respectively.
You’ll need Renesas GATTBrowser App (or any other means to connect to BLE devices and modify settings).
A) To read a lighthouses channel number via BLE advertisements:
Open RENESAS GATTBrowser
Tap on LHB-12345678 (not the blue play arrow, just anywhere else in the line)
The Raw-Data section flips open
Under “Manufacturer Specific Data”, find a string beginning with “055D: 00 02 ?? ...”
The third number is you channel number, it is advertised frequently, also in stand-by state
B) To read/change the channel number via BLE characteristic:
Press the blue play button of the lighthouse you want to change the channel for
GATTBrowser now connects to the lighthouse
Find the line that starts with “00001524-1212-...” and tap on it
Make sure to press the “Read” button.
Below there should appear the exact same value as from section A) above, e.g. 01 for first channel
Under the Write button, there is a line for text input; type a new channel number, e.g. “02”, there
Make sure that next to the Write button, “Hex” is selected from the dropdown component
Press “Write”
In case the Lighthouse was spun up and you have very good ears, you will notice a faintly changed sound pattern.
If you see the lighthouses in SteamVR, you can use hmdq (https://github.com/risa2000/hmdq) to see which channels are they running on. It spits them as ModelLabel property in the list of properties of TrackingReference (which is SteamVR nick for the lighthouse). It will also show you the corresponding serial number, so you can relate the two.
