Great work on PE so far guys! One thing I’ve noticed is there doesn’t appear to be a method of adding a command line to imported executables. A few imported apps I have require custom command lines added to run properly. When importing an app, it only gives the option of running the exe directly.
Could you possibly add the option to modify the command line when the exe is run?
For example: …exe" -openvr
