Comfort Topstrap
Hello.
I saw Pimax start selling Comfort Topstrap with Cristal https://pimax.com/crystal-comfort-topstrap/.
But i have 8KX. Is Comfort Topstrap work with 8KX? And how much does it cost?
Website for just new top strap $18US.
Not sure if earlier models have the screws in that area to attach.
Judging by pictures they posted might be around those thin pads
Maybe @PimaxQuorra might be able to check it out.
If not have an idea to make an easy knock off Using a ratcheting helmet/face shield. Likely good for any headset. (Similar in cost)
Hello,
Theoretically, it’s compatible with the 8KX series. However, to be certain, I’ll double-confirm with our engineering team and get back to you with an update as soon as possible.
