So I did a mod for my Oculus Quest and thought that some of You guys without a DAS (or MAS until it arrives) might be able to use the same stuff for making the Pimax a bit more comfortable:
One side is the soft part and the other side has a strip of velcro so it can easily be cut to fit with a pair of scissors.
EDIT: Here’s another image to show the thickness of the fabric:
