Could you tell me where it is located?
Of course! Log files are located in the following folder:
C:\Users\<YourUserName>\AppData\LocalLow\Pimax\Pimax VR Experience\
Since the AppData
folder is a hidden folder, you can simply paste the address in the address bar in Explorer.
The log files are named: player.log
and player-prev.log
Edit: It may be helpful if you kindly supply your settings file as well. The settings file is located at the same location as the log files, and is named: userSettingsPVR.json
Thanks for the idea. I’ll add the possibility to the next update (phase 2).
