I received my headset yesterday, but no controllers or base station (I understand they are being shipped much later…). In the meantime the headset is almost useless without at least a controller. Are any of you using any cheaper basic controllers that would are compatible? So I can buy in the meantime whilst waiting as I don’t really want to shell out for full Vive whatever parts just to use for a few months.
Without a tracking solution the only controllers you could use are game peripherals such as joysticks/wheels or a game pad. These will obviously limit what games you can play.
I went with a second hand vive to get wands and lighthouses.
Definately a cheap solution for now, get an Xbox controller, easy to hook up because its microsoft and works good with windows. I heard PS controllers will work too. Lots of great Steam games can be played with it. Find the Steam game you like check on righ side of screen and in blue text it will have “Full controller Support” with an icon of a game controller if you can use Xbox controller. Have fun!
If you own or can buy Psmove cheap you need 2 ps3 Cameras & a pingpong ball & a light to iluminate pingpong ball. Reccommend getting driver4vr(youtube it). I have the ps3 cameras but need to get controllers.
I have a number of games working natively with the xbox controller including:
Skyrim (FOV-large_ and resolution are breathtaking)
Subnautica
Solus project
Edge of Nowhere
But many others do not, including:
Alien Isolation
Island 359
Contagion Vr Outbreak
The Forest
Contractors
Wardust
Pavlov
Zero Killed
Even though my controller is seen by Steam. I’ve played around with the controller settings in Steam with no luck so far. Any helpful tips are appreciated.
I very much miss using the Oculus Touch controllers (best on the market currently) which sit idle on my desk while we wait for the Pimax controllers in 6 months, maybe.
Thanks all very helpful. I found 1 game in my library that workjs with no base stations and no VR controllers… IL2 Sturmovik BOS (Battle of Stalingrad). Pretty cool with a POC joystick. It needs a joystick though (you can fly with mouse).
The feeling of being in the air when you are banking low, and you look at the ground is excellent.
Anyone know if Skyrim VR can be played with no VR controlllers and base stations?
