Changed pledge to Early Bird from Standard
I just changed my pledge from an 8k standard complete set to the $50 reduced early bird set… I didn’t notice one was still available before… Maybe someone shifted to an X or something?
So, I notice that adding accessories means manually changing the pledge level by the amount asked for.
Can I ask for $50 worth of accessories like another strap and a couple of face pads?
@deletedpimaxrep1 @Matthew.Xu @bacon
Added some pokes to your post to team members.
Yeah people are starting to get cold feet, I snagged the $50 discount as well :smiley:
Logically you should be able to drop your pledge by $50 or if you want other accessories, calculate the price and check that it matches.
You can drop your pledge amount no problem, as long as you don’t drop it below the amount it requires to get your reward you will be fine.
:wink:
Getting an early model would scare me. This is a revolutionary headset… really don’t want the first one in case there are manufacturing issues. Even if Pimax support is great, I don’t want to wait for shipping to and from China for a fix/replacement. Good Luck! :slight_smile:
I’m pretty sure the early bird is just cheaper, I don’t think it reflects when my actual headset will ship. Someone correct me if I’m wrong?
Thats my understanding. Shipping i think they said went by backer #…?
Yep, that’s what I thought also. I’m thinking the “early bird” is just a limited reward because it’s $50 cheaper, just for the people who pledged first.
There is no difference except price. ‘Early bird’ just means one of the first backers, and it is a common kickstarter terminology… Although inexperienced kickstarter backers might not realize by default…
That makes sense.
I just saw 1 was available and switched over… $50 is $50.
Never even thought about the delivery order priority. LOL
Funny how there’s a few cold feet, but it’s nearly up to 4 mil. And I’m pretty sure it’ll pass it before end
Yes, you may change and pledge $50 more in your Kickstarter central. We will send a survey to you through Kickstarter soon to gather your order details.
