Change résolution
Hello,
I have thé pimax and i have problem to change résolution.
My computer are connected in HDMI on my tv!
Config: i7 67000k
16go ram ddr4
zotac gtx 970 amp extreme core
Can you help me to change résolution?
Thanks.
Maybe he can help you!
http://community.openmr.ai/t/i-found-a-useful-custom-resolution-tool-4k-60hz/162/26?u=zyyzyyzyy1
Thanks, but it’s not the good Key!
Try this
Thanks.
Can you explain me how use this app?
Thanks
rzae, I think after install the application you can change the resolution from windows screen resolution.
After install it, in piplay extend mode, I can change the resolution from 1080p to 2k or 4k.
I don’t know how to change in direct mode (pimax mode), I think it should be changed from the game configuration itself (but for me, in Fallout 4 with Vorpx not work well).
i tried this i now can’t lanch any games from from steam vr…it looks better in extended mode in 1440p …how to a change back before install… this headset is not a consumer product yet the reality is that i have paid hundreds of pounds to be a product tester.
