Center shifting to right
Hello, I am new of Pimax 4k so I could have missed something … anyway my problem is as follow:
I am using Pimax with Steam VR and it works fine. After I have done room configuration in steam and I start to play (Elite dangerous) or using Simple VR Video player I have the “center of the screen” shifting to right … long story short to see in front of me in VR I have to turn my head in real world to almost 90° on the right.
Any suggestions? Thank you …
I have this exact issue in the same game i find myself turning in my chair with out noticing taking the headset off and being the opposite way to when i started.
Hopefully you find a answer to this.
There is no answer to this problem. It is caused by lacking positional tracking. Nolo presumably helps. Some people have said that facing North during room setup and after helps.
I have red the same … today I will try, did it work for you?
