@bacon @deletedpimaxrep1
In the kickstarter you mentioned that Pimax lighthouses will support Steam VR Tracking 2.0.
I have a lot of questions that are more about the details.
Does Pimax build their own lighthouses, or will you ship the new Valve lighthouses?
If they are your own design, do you get the specifications and firmware from Valve, or do you have to reverse engineer their lighthouses based on public information?
Does Valve validate your lighthouses to make sure they meet their specifications and are fully compatible?
Are your lighthouses single rotor or dual rotor with sync on beam?
Can your lighthouse firmware be updated to later support the new features of Steam VR tracking 2.0 (Using 4 Basestations or more)?
Does your lighthouse hardware support frequency-division multiplexing (FDM), so it can be enabled later if Valve starts supporting it with their own lighhouses?
Will your lighthouses turn off automatically when SteamVR is closed?
Best regards
