Can use pimax 4K just for replace UHD monitor to working?
Can we use pimax 4K just for replace UHD monitor for working but we not use gpu in it, just intel hd graphic
It will not run I think. Perhaps the display itself runs, but you have no usable image
Yeah intel igpu not likely to work well at all.
Just checkout
-Virtual Desktop
-VR toolbox
-Bigscreen beta
As those are designed for desktop type use. Look over requirements. & google your intel gpu with the above names
At best you can use it to replace an ultra LOW definition monitor.
