One of the the associated early HMD defects I’ve seen here is the bad cable one. If we are able to replace our cables, can Pimax essentially accessorize the HMDs by either future models come with a single cable or the Virtual Link cable can be purchased separately should you choose. First HMD on market to support that would be dope and skyrocket it’s demand imho.
Agreed for sure but, it is obvious they are on the correct path and proving they can with the latest pi-Beta alone. Another bucket list item i suppose as I do not own another HMD and seems like Pimax HMDs are more configurable.
If the Pimax WIFI module gets released, then the need for a cable and or virtual link will become redundant. is defiantly a viable option if the WIFI module option falls through though.
Can it truly fully power the demands of the high resolution of Pimax HMDs
Should the answer be yes it can
For how long?
My assumption on number 2 is 3hrs granted i would very much welcome a great usage time output without having to strap an all around belt full of battery backs on your waist. But come to think of it, if you are playing wirelessly maybe beat saber, fps etc… maybe 3hrs is all the average user would use hey
i think the average user would be within those ‘3 hours’ usage…or very close… even some of the longest movies are around 3 hours… but for the crazy-gaming-obsessed vr enthusiast that can go 6 hours straight… then the cable option would be better anyway as the throughput would make it smoother.
